68 AM/FM Yellow Radio Card - NCRS Discussion Boards
  • Jack C.
    • September 30, 1992
    • 1090
    Since this card is not mentioned in the Owners Packet items, does having one for Flight judging matter?
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
  • Reba W.
    • 938
    Re: 68 AM/FM Yellow Radio Card
    The radio instruction sheet is listed in the owner's packet. This is a folded page printed on light beige/yellow paper. But you may be referring to the tag that hung from the radio knob.
    • Jack C.
      • 1090
      Yes, that is the card I'm referring to. Does it matter if you have it or not?
      Jack Corso
      • Reba W.
        • 938
        We do not look for it at the present time. However, a revision of the JG is in the process. (Won't be used before the convention.)
        • Jack C.
          • 1090
          Thank you.
          Jack Corso
          • Dave S.
            • August 31, 1992
            • 2930
            Along with other unique paper items 68's and 69's had a radio tags that were installed on one of the radio knobs. The tag was different from the mid year style in wording and color. The mid year tags were a darker yellow and the 68/69 tags were pale yellow. My research also indicates mid/late 67 cars also used the pale yellow tags.
            The radio sheet Reba refers to would be a white fold open booklet with three possible part numbers; #968, #199 or #110 for 1968 cars. The #110 sheet would be for 1969, 1970 and possibly early 1971.
            I'll try to post photos of the two different radio tags.
            • Dave S.
              • August 31, 1992
              • 2930
              The first two photos are the darker yellow 65/66 and early 67 radio tag. Second two are the pale yellow late 67, 68 and 69 radio tag.
              • Jack C.
                • 1090
                Thanks Dave. I have the more pale yellow card with my 68. The originals have the hole punched out while the repros that I have seen have a slit to take it on and off.
                Jack Corso
                • Jeff P.
                  • 799
                  Hey Guys,
                  My radio card has wire instead of a type of string. I was told it did come with wire. Interesting. Jeff
                  68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
                  2014 Arctic White Z51 Vert. (Wifes)
                  • Dave S.
                    • August 31, 1992
                    • 2930
                    Jeff,
                    I'm no expert but I've seen a lot of radio tags and never seen one with either a wire or a string.
                    Now, Headlight washer tags or wiper over-ride tags are a different story.
                    • Jeff P.
                      • 799
                      You are so correct Dave. I apologize Joe, I was refering to the overide tag. Always learning here. Jeff
