C1 brake line installation question - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2585
    I'm installing the brake lines on my 60 restoration. I am using the BTW steel lines.
    I have read on other threads that I should tighten-loosen-tighten the fittings to get them to seat good.
    My question is how tight do I tighten them to try and make sure I don't have any leaks?
    I'm primarily talking about the fittings into the wheel cylinders and into the brass blocks, etc, and I am using a proper line wrench.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Pat H.
    • December 1, 1996
    • 419
    Re: C1 brake line installation question
    I,ve replace a few lines on my 59. Master to brake block and right rear line. All I did was to make sure they we tight with no movement. So far no leaks after a number of years. SS lines are a pain if they don't seat properly the first time.
    • Bruce B.
      • May 31, 1996
      • 2930
      I have replaced the lines on 2 of my 62s using steel lines with no problems. Just use the proper tools and make them TIGHT.
      On my 57 I used SS lines with DOT 5 silicone fluid. Had a few leaks but after tightening a few times absolutely no leaks after 3500 miles.
      • Donald H.
        • November 2, 2009
        • 2585
        I going to use Dot 5 also. But not SS line. I figure the BTW will out last me a few time over. Plus this will not be a daily driver, but I do plan to drive it.
        Don Harris
        • Bruce B.
          • May 31, 1996
          • 2930
          Donald,
          Good decision on the lines and the DOT5.
          I have had great performance from the DOT5 in a few cars and I like the fact that it is not a paint remover.
