Tire ramps - NCRS Discussion Boards
Tire ramps
  • Jerome P.
    • October 22, 2006
    • 607
    Tire ramps
    I am thiking about a pair of ramps to enable me to do some minor work, oil changes etc, under both of cars ('72 and an 03)
    would like get the cars as safely high as possiible.
    What is a reasonable height?
  • Joel T.
    • April 30, 2005
    • 765
    Re: Tire ramps
    Jerome;
    While not exactly "ramps", I have had good success with a Quiklift... It is basically a set of long (and adjustable) ramps which you drive up on, and then use a floor jack to raise the back end up.. Once raised, the car is level and about 18" off the ground which is good to do what you are looking to do plus other repairs.
    I use the Quiklift with my '63 and '65 all the time, but have not tried it yet with the '10
    Joel
    • Chuck S.
      • April 1, 1992
      • 4668
      Re: Tire ramps
      Jerome...Are you the last sucker in the world to buy some of those ramps? I've had two pair...the last pair (a gift) I sold as scrap in a recycle load.
      They're a giant PITA...Heavy and hard to position; stored they seem to occupy twice as much floor space and are always underfoot; when you contact the ramps with your wheels they are likely to slide forward; if you have a late model Corvette, the front air dam is going to interfere with the ramps.
      I'm better off without them taking up space in my garage...but that's just my opinion.
        • 6956
        Re: Tire ramps
        Jerome, The 72 will be no problem with ramps, But the 03 is another story, they are very low to the ground and would require a lower profile ramp, to me as chuck says they can be a pain, and for safety reasons would require another set of eyes to tell you when to stop.
        • Jim M.
          • August 31, 1986
          • 50
          Re: Tire ramps
          Jerome: I have used ramps for over 40 years to work on my Corvette. It is scary driving up on them but get a friend to spot for you when you do it. The sliding forward is easily cured by having a hole at the bottom of the incline and attaching a piece of rope extending toward the car so that when the weight of the car is on the rope, the ramps can't go anywhere. They also make the world's safest jackstands if you have two floor jacks and can lift both sides simultaneously until you are high enough to get them under the tires.
          Regards, Jim
          • Timothy B.
            • April 30, 1983
            • 5201
            Re: Tire ramps
            I don't have a lift so the ramps are the next best thing for me. I usually lift the car with a floor jack then slide the ramps under the tires, very nice room to work on the underside of the motor and frame.
            If I am tired and it's warm enough I will even close my eyes for a while and nap while I'm there..
            • Jack C.
              • September 30, 1992
              • 1090
              Re: Tire ramps
              Rhino ramps. Made of heavy duty plastic and they won't slide.
              Jack Corso
              1972 Elkhart Green LT-1 Coupe 43,200 miles
              Top Flight 1994, 2018 & 2021
                • 43273
                Re: Tire ramps
                Jerome-----
                Race Ramps are the answer (www.raceramps.com). I have the 67" set. These raise the car 10" which provides adequate clearance for most jobs. They are 2 piece, so you can remove the ramp portion after the car is up on the ramp to provide better access under the car. They have ant-skid provisions to prevent them from "creeping forward" as you drive up on them.
                They are extremely light so handling them is no problem, at all. The incline is gradual enough so that with these ramps any C1, C2, C3 or C4 Corvette can be driven up the ramp without interference with the front air dam or other parts of the car. I don't know about C5 or C6.
                There are only two downsides that I can see to these ramps. First, they are rather expensive. Second, they do require quite a lot of room to store. However, they are light enough to be hung on a wall.
                • Craig H.
                  • December 17, 2010
                  • 59
                  Re: Tire ramps
                  You may have to do some looking but these are available in Australia and the UK.
                  They go down to nothing so low cars are fine and up nice and high.
                  I paid about $300 for the pair.
                  http://www.radum.com.au/catalog/prod...oducts_id=8099
                  • Jerome P.
                    • October 22, 2006
                    • 607
                    Re: Tire ramps
                    Craig, these look really great.
                    Joe, do you have the 1 or 2-piece ramps? I would guess yours are the 1-piece.
                    For a C5 I think the extensions would be needed. I am going to call them tomorrow, but would like as much info tonight.
                    Has anyone any else had experience with the unit Craig presented?
                    Thanks to everyone.
                      • 43273
                      Re: Tire ramps
                      Thanks to everyone.
                      Jerome-----
                      I have the 2 piece, 67" ramps.
                      • William M.
                        • July 31, 1993
                        • 390
                        Re: Tire ramps
                        I have the one piece Raceramps. They work fine for my C3 and C6. They are light weight and don't take up much room if you store them standing up.
                        Bloomington Gold 2011
                        Corvette Magazine 9/11
                        Bloomington Gold 2013
                        Corvette Magazine 3/13
                        • Peter J.
                          • September 30, 1994
                          • 586
                          Re: Tire ramps
                          Joe,
                          $352.00? Sure sounds like a lot for light-weight ramps. I like the design of the two piece unit as that is right where you will be spending a lot of time in that area (oil changes, etc) but I guess I'm too cheap and will have to stick with the floor jack and jack stands.
                          • Michael W.
                            • April 1, 1997
                            • 4290
                            Re: Tire ramps
                            http://www.cjautos.site90.net/newprod.html
                            Craig,
                            Those are really sharp. I've done some googling but cannot seem to find any source for them in N. America. Anybody got a link?
                            • Chuck S.
                              • April 1, 1992
                              • 4668
                              Re: Tire ramps
                              Yeah, I like those too.
                              If you're not using your garage as a resto shop, and just parking your cars, you can probably anchor them down to the floor and just leave them...no worry about moving them, stowing them or tripping over them. And, no worry about low approach angles.
                              It looks like the hydraulic cylinder pushes the ramp assembly rearward over center to lock, so you would have to plan for that rearward travel of the car when lifting.
                              I can't find a NA source anywhere either...just Craig's Aussie and UK links. I'm thinking it's the same company with an Australian outlet. Pretty smart of the Brits to come up with this...they must still have some greasy-handed tractor engineers over there.
