Half Shafts - NCRS Discussion Boards
Half Shafts
  • Robert P.
    • November 1, 2004
    • 66
    Half Shafts
    Do Half Shafts need to be balanced ? Thanks Bob
  • Dick W.
    • 10483
    Re: Half Shafts
    If they have had the yokes or the tube replaced, yes
    Dick Whittington
    • Robert P.
      • November 1, 2004
      • 66
      Re: Half Shafts
      Thanks for the info. I am doing a trailing arm rebuild so I thought it would be a good time to clean up the half shafts and install new U joints.
      • Larry M.
        • January 1, 1992
        • 2700
        Re: Half Shafts
        The half-shafts are not balanced because of their much slower rotational speed. New u-joints should not affect balance/performance of the half-shafts.
        The driveshaft is another story. I had mine rebalanced after replacing the u-joints. The replacement u-joints were significantly different and had more mass than the originals ones that I replaced. However, even then, the affect on the original balance was minimal.
        Larry
