'65 Pitman Arm Socket Size - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I need to buy a socket to remove the pitman arm nut. Can I get the socket size please? Thanks Larry
  • Timothy B.
    • April 30, 1983
    • 5201
    Re: '65 Pitman Arm Socket Size
    Larry,
    I believe it's 1 5/16".
    • Bob R.
      • June 30, 2002
      • 1595
      1 5/16" is correct I just removed mine. You may need a pnumatic gun to get the bolt off it was very tight. You will nedd a puller to remove the pinion from the steering box.
      • Jim T.
        • March 1, 1993
        • 5351
        Some of the auto parts stores loan tools for a deposit. Comes in handy to borrow sometimes instead of buying unless you want to increase your tool ownership.
        • Wayne M.
          • March 1, 1980
          • 6414
          Originally posted by Timothy Barbieri (6542)
          Larry,
          Check out the "similar threads" below on subject of Pitman Arm Nut. Fit to socket seems to be an issue, at least sometimes.
