Were all balancers in '61 6" in diameter? What was the difference between the standard and SHP balancer. I am trying to figure which one I have. Thanks Larry
'61 Harmonic Balancer Question
Re: '61 Harmonic Balancer Question
They were all ABOUT 6" OD but I don't know that they were all EXACTLY 6" OD.
Both balancers are "stepped" and, basically, the easily identified difference is this: the lower HP balancer has a reduced OD section on the front and the larger OD section at the rear. The SHP balancer has the larger OD section at the front and the reduced diameter section at the rear.In Appreciation of John Hinckley- Top
Larry,
Pictured is some of the research that I did on harmonic balances about 20 years ago. At that time I also collected about 20 or more balancers from 1960's Chevrolet 283 junk yard cars. The photo on the left is research on 62-65 250 & 300 HP balancers (I call this a type "B" in my research) but the 1959-1961 balancers that I found are the same shape but the part numbers are different. The photo on the right shows the 1966-1967 low HP balancers. The type "E" is from my research only.
low HP Corvette balancers
1958, GM # 3743849 (type "A", no holes around rim)
1959-1961, GM # 3760584
1962-1965, GM # 3817684 & GM # 3861968 (type "B", 12 holes around rim)
If you need a stepped balancer send me a PM. According to my notes I have one from a 1960 Chev. 283 w/P.G. "T0609D", a 1961 Chev. 283 w/P.G. & 4BC "T0403DB", and many more.
DaveLast edited by David L.; February 10, 2011, 02:11 AM.- Top
David, Just for information sake, I'd like to jump in on this discussion. I have a low HP '61, which would fit your #684 left side attachment, but mine does not have the holes on the thin part of the balancer. It is solid. Do yo have photos of the different variations?- Top
I have up-loaded pictures of two balancers, front and back views. The balancer on the left are for the low horse motors and the balancer on the right is for the high horse motors.
RayRay Carney
1961 Sateen Silver 270-HP
1961 Fawn Beige 315-HP- Top
NOTE: My type "A" stepped balancer weighs about 6.7 lbs. My type "B" stepped balancers each weight about 6.4 lbs. I guess by drilling 12 holes the weight is reduced by about 0.3 lbs.
DaveAttached FilesLast edited by David L.; February 10, 2011, 09:45 PM.- Top
Do you know the model year of your low HP balanced (without the 12 holes)?
Dave- Top
The pictures of the low horse balancers were provided to me by a friend for a chassis presentation that our chapter is having this spring. I cannot tell you exactly what year they were removed from, but were listed for a 1958-1961 low horse engine. The research I have done would lead me to believe that they are for 1958 to 1961 model. I believe that the earlier balancers had the pulley attached (riveted) to the balancer. I do not have a date when this practice ended and the style in the above pictures started. Maybe someone with knowledge on the 1956-1957 models will comment.
I am attaching a picture of a 1956 balancer.
RayAttached FilesRay Carney
I looked through all my 58-61 low HP balancers and only a few were tagged.
The 2 photos on the left are of a balancer from a 60 Chev. (eng. stamped "T0328E" , intake casting date "C 21 60"). Note that the large diameter part is made from thick sheet steel and has 12 holes. I call this a type "C" balancer and weighs about 3.1 lbs. I have no idea what the GM part number might be.
The 2 photos on the right are of a balancer from a 59 Chev. (engine stamped "T0520D", glass code was "JY" or May 1959). This balancer has the 12 holes.
I have to assume that both of these balancers were original equipment. Both came from car in a junk yard in Northbridge, MA.
I have noticed that the rivet heads on my many 58-61 balancers have different markings. I assume that there was more then one vendor that made the balancers. Did one vendor make the balancers with 12 holes and use plugs for balancing and the other vendor just drill shallow holes for balancing?Last edited by David L.; February 12, 2011, 04:10 PM.- Top
