'61 Harmonic Balancer Question - NCRS Discussion Boards
    Re: '61 Harmonic Balancer Question
    Balancer's with the 'woodpecker' holes on the outer ring are well known for having been factory original to low horse, '66-67 SB engines...
    • David L.
      • July 31, 1980
      • 3310
      Jack,
      I assume you are referring to the balancer with the stamped steel outer ring when you say " the 'woodpecker' holes on the outer ring". It is very possible that the balancer I found on the 60 Chevrolet 283 was a replacement as a lot can change in 31 years (1960 to 1991).
      My 1966 & 1967 Chevrolet Parts Catalogs (Oct. 65 & Apr. 67) show GM # 3883956 as the balancer part number for "66 ALL w/nodular crankshaft (283)(1st design)" and described as "w/o pulley (6 1/4 O.D.)". GM # 3883956 does not appear in my 1965 Chevrolet Parts Catalog (May 1965) or any earlier parts catalogs. If you say the "woodpecker" balances were used on low HP 66-67 Chevrolets then I would say the GM part number is 3883956. GM # 3883956 was then replaced with GM # 3861970 in Nov. 1967.
      Dave
        Dave -
        As far as I know, no Corvette 283 engine was ever built with a nodular iron (cast) crankshaft; all of them were forged steel. The use of nodular cast iron crankshafts for some 283's started in 1965, long after Corvette 283 usage stopped in 1961.
        • David L.
          • July 31, 1980
          • 3310
          #19
          Dave -
          John,
          I never stated that the 283 Corvette engine used a nodular crankshaft.
          The term "ALL" when used in the Chevrolet parts catalog means all passenger cars EXCEPT for the Corvette. According to the 66 & 67 parts catalogs the 3883956 is to be used on all 1966 Chevrolet passenger cars (not the Corvette) with the 283 nodular crankshaft (1st design).
          Dave
            • 43275
            #20
            John,
            Dave
            Dave------
            I don't think that ANY 283, Corvette or otherwise, used a nodular iron crankshaft during the C1 period of 1955-62.
            • Bill B.
              • December 1, 1993
              • 192
              #21
              I was always under the impression that this is a picture of a 270, 290 & 315hp balancer.
              Bill
              1961 Black/Silver/Red Int. 283/315 FI
              power windows. Frame off 65% completed.
              1989 White/hard top/Grey Int. daily driver 167,000 miles
              The problem with Liberalism is that eventually you run out of other people's money" - Margaret Thatcher
              • Ray C.
                • June 30, 2001
                • 1132
                #22
                Bill
                Hi! Bill
                There should be no holes on the outside ring. I have been told that the balancer like the one pictured was used on the 348-CI engine. (I have never seen one) A vendor at Carlisle, I was looking for a HP balancer for my 61 FI project, told me that he has seen people thread, plug and then balance the 348 balancer to look like the High performance balancer. There is a vendor (seen the balancer in his booth at Carlisle) that has been modifying balancers for the high performance balancer and they look like your balancer.
                Ray
                Ray Carney
                1961 Sateen Silver 270-HP
                1961 Fawn Beige 315-HP
                  • 43275
                  #23
                  Originally posted by Ray Carney (36314)
                  Hi! Bill
                  Ray
                  Ray------
                  The problem is that GM says that the balancers for 283's and 348's were the same. There was a part number for lower performance 283's + lower performance 348's and a part number for higher performance 283's + higher performance 348's.
                  After the late 60's, the GM #3896904 became the SERVICE balancer for all.
                  • Loren S.
                    • November 1, 2002
                    • 172
                    #24
                      • 43275
                      #25
                      Originally posted by Loren Smith (38825)
                      Loren------
                      I wonder how he knows it's a GM #3764318?
                      • David L.
                        • July 31, 1980
                        • 3310
                        #26
                        Loren------
                        GM # 3764318 is the balancer part number for 1959-1961 Corvettes w/H.L. cam, H.P. and was discontinued in November 1962 and replaced by the 3817684 balancer (1962-1965 models). The seller might be correct as I have never seen a balancer like this.
                        • Ray C.
                          • June 30, 2001
                          • 1132
                          #27
                          Hi! Joe
                          Thanks for the information about the HP balancer. The information that I posted was from vendors at Carlisle when I was on the hunt for a HP balancer . Is the balancer that Bill Berger pictured in his post the service replacement balancer? If not, would you know the application for this balancer.
                          Thanks for the correct information!
                          Ray
                          Ray Carney
                            • 43275
                            #28
                            Hi! Joe
                            Ray
                            Ray-----
                            I do not know whether the balancer pictured started life as a PRODUCTION or SERVICE piece. I've never been able to figure out the "holes versus no holes" issue.
                            • Robert B.
                              • December 1, 1999
                              • 56
                              #29
                              Guys,
                              For what its worth here is another couple shots of the 270 horse balancer I have for my engine. I agree with Ray & Loren that there were no holes on the outside ring. I believe my balancer is the same style as the one on eBay. Note that one of my pictures includes the picture shown in the technical information & judging manual page 74 for a quick comparison. My balancer was rebuilt by dampner docs before I bought it and the enamel is baked on pretty thick and I can't make out any numbers if there are any.
                              • David L.
                                • July 31, 1980
                                • 3310
                                #30
                                I am convinced that the 59-61 Corvette w/ H.L. cam, H.P. balancer (GM # 3764318) has been identified.
