58 107 Coil - NCRS Discussion Boards
58 107 Coil
  • John N.
    • February 1, 1975
    • 451
    58 107 Coil
    What is the best source for the most correct reproduction (or real) coil?
    Thanks!!!
  • John N.
    • February 1, 1975
    • 451
    Re: 58 107 Coil
    Let me try once more.
    Thanks!!!
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: 58 107 Coil
      John,
      Paragon sells GM Restoration Products 107 and 091 coils.
      They look pretty good except for the raised boses on either side of the tower. The 107 or 091 along with 12V is a raised stamping near the top of the coil. In have a new 091 that I am looking at now.
      These boses can be "removed" to make the coil more correct.
      They get $160 which seems high for a repro, but then where else can you find one. It looks like CC sell them for $89.95?
      Good luck.
      • John N.
        • February 1, 1975
        • 451
        Re: 58 107 Coil
        Bruce
        Thanks again!!! Does anyone know the differences between the Paragon and CC coil?
        Regards
        • Ridge K.
          • May 31, 2006
          • 1018
          Re: 58 107 Coil
          pushing back up ......
          • Dick W.
            • 10483
            Re: 58 107 Coil
            John, unless I am mistaken, there is only one company reproducing the coils. I do not think that anyone is reskinning coils anymore.
            Dick Whittington
            • John D.
              • December 1, 1979
              • 5507
              Re: 58 107 Coil
              Do you all know the history of the 107 coils? Dale Pearman taught me years ago that the coil started off life on heavy equipment such as ff road vehicles, school buses,etc..
              It was not originally designed for Corvette. JD
              • Timothy B.
                • April 30, 1983
                • 5202
                Re: 58 107 Coil
                And I know where one is, there is a 10/15 ton Buffalo Springfield asphalt roller I used to own with a four cylinder continental engine. Vintage late sixties with a 107 coil, I am almost positive.
                Guess I better go take another look at "BABY DOLL"
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Re: 58 107 Coil
                  The 091 coil I have is a new GM Restoration part and the 091 and 12 volt embosing is about 7/8" from the top of the coil. According to the 61-61 judging manual these markings should be near the bottom of the coil. If I assume the 107 is in the same position then they are both incorrect.
                  • Jimmy B.
                    • July 31, 1980
                    • 584
                    Re: 58 107 Coil
                    Have Ken Keyser post a photo of the original owner 61 107 coil I sold him at Kissimmee this year. Taken off the car before 1984.
                    Jim
