On my new ignition harness there is a black & pink wire with a black connector on it that i think connects to the plus side of the coil, But there is also a black wire with the same type of connector on it,i dont know where it goes.
My other question is, on the main harness i know that the windshield wiper motor harness in the ignition wire goes threw the fire wall, the black in pink wire goes to one side of the resistor, could some one tell me where the wire comes from that goes from the other side of the resistor to the coil, in to the R side of the sol.switch.
THANKS.
THANKS.
] Was it running before ? You have purchased a new engine harness (goes from the inboard firewall connection to the volt regulator, horn relay and horns, and alternator, on the driver side, and to the blower motor and starter on the passenger side). Can you tell us from whom you bought this and the part # ?
