65 Seat Tracks - NCRS Discussion Boards
65 Seat Tracks
  • Richard R.
    Infrequent User
    • April 30, 1988
    • 9
    65 Seat Tracks
    Working on my seat frames. After I get the sand and dirt out of the tracks, should they be lubricated? If so, what should I use? I'm replacing a few missing spring bushings, just not sure if they operate metal to metal, or get lubricated. Thanks
  • Willard M.
    • August 31, 1979
    • 422
    Re: 65 Seat Tracks
    My understanding is no grease, etc. as that will get gummed up. Simply springs on metal.
    • Clark K.
      • January 12, 2009
      • 536
      Re: 65 Seat Tracks
      Sand in the tracks? Oooh, someone must have sandblasted it in the hope of restoration. Never sandblast your seat track mechanisms because it is almost impossible to get the sand out of the insides. Use phosporic acid to strip off the rust and then use a rotary wire brush, if necessary. You can then use a light coating of oil on the outside of the tracks to keep the rust off (or spray with clear paint). -Clark
      • Gary B.
        • February 1, 1997
        • 7053
        65 Seat Tracks; I believe they were greased
        Richard,
        When I restored the seat frames on my '66 I saw lots of evidence of 40-year old dried up grease in the tracks. I used chassis grease after cleaning, welding, restoring, etc., the frames/tracks when I put the tracks back into the tubes. I'm glad I did, since I love the way they slide.
        Gary
