should the front bracket have the reinforcements or not.
67 differntial mounting bracket
Re: 67 differntial mounting bracket
Keith -- I'm not a '67 expert, but I believe you should have the forward reinforcement washers shown in this TSB, and released (with washers) as # 3868799, in production. I believe it wasn't until the C3 era that they added the plate to each side of the bracket, to support both forward and rear bolts. This latter design also had the forward lip of the bracket removed. Others will probably revise my description, if I'm not correct.
- Top
- Top
