correct fan shroud and dust shield staples/material? - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    From doing some reading I need to buy 16ga blister pack steel wire, correct? not sure what it's meant by blister-pack. Does it need to read galvanized, ss or what?
    I read where judges check if they're magnetic or not but didn't see where they're supposed to be or NOT supposed to be magnetic.
    So, a little unsure what to go buy at lowes/home depot at this point. The pre-formed ones that came with my dust shields from paragon are magnetic. I read where the pre-formed oens that most restoration places carry are SS (ss=non magnetic) but again mine that came from paragon are magnetic which would be correct and they look different (less shinny) from the galvanized steel fence wire on a roll that I have.
    which makes me question maybe paragon and other places have stepped it up to be more correct and perhaps the ones from paragon are really what I need to be using. Confused.
  • Alan D.
    • January 1, 2005
    • 2054
    Re: correct fan shroud and dust shield staples/material?
    The one's from "paragon are magnetic" and that is Correct.
    Also the thickness of the rubber in the past has been toooo thin.
    You want 3/32, although the repo's were at 5/64 even I could tell
    the difference by feel.
    There have been some excellent past posts on how to bend the staples however I just can not find in my notes.
    • Brandon T.
      • October 23, 2008
      • 872
      Well from what I read the ones from paragon are ss and not magnetic so I guess what I'm saying is mine form paragon aren't ss.
      anywho I will keep researching the acrhives but if anyone has experience with this post here too. thanks
      • Jack C.
        • September 30, 1992
        • 1090
        Brandon, make sure they are painted the engine bay color as well because they were installed at that time of blackout.
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Alan D.
          • January 1, 2005
          • 2054
          And naturally the dust shield is painted blackout also - at least it makes painting simpler.
          • Brooks G.
            • December 1, 1978
            • 286
            Brandon, just because the material is stainless steel does not necessarily mean that it is not-magnetic. In the past I have worked with some stainless steel that was magnetic and would also rust. 17-4 ph is one example of a stainless that is magnetic and will rust. I wish you good luck with your restoration. Brooks Glover (2141)
