62 side radiator seals on 340hp - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8400
    Re: 62 side radiator seals on 340hp
    Originally posted by Terry Deusterman (11486)
    Anybody know where to get those clips?
    got mine from corvette central recently.mike
    • Terry D.
      • May 31, 1987
      • 2696
      Mike
      • Anthony P.
        • June 27, 2010
        • 485
        #18
        Thank you Mike.
        I had 4 clips already on my car, and 2 were missing. Paragone had some that were restored (however, just raw silver with no plating). They were a perfect match to what was already on the car.
        https://www.paragoncorvette.com/p-35...-retainer.aspx
        Paragon Number: 6514
        GM Part Number: 3795485
        Tony
        • Christopher R.
          • March 31, 1975
          • 1599
          #19
          Tony,
          1. Are you going to paint or plate these clips black? Or, use them as is in the silver color?
          2. Any trick to installing these clips? Or, do they simply push in?
          • Anthony P.
            • June 27, 2010
            • 485
            #20
            Christopher,
            1. I will black them out with the same blackout paint I use in the engine bay. (The ones I pulled out did have black paint on them, and Mike confirmed they should be black.) On my original ones, I use some paint stripper to get the old paint off, then very lightly blasted them to get the rest of the paint in the tough spots.
            2. I have not put them back, in, so not sure of any tricks. I did use a screwdriver to pry them out and they came out pretty easily, so I assume I can just push them back in. Maybe a tap with a rubber hammer.
            Originally posted by Christopher Ritchie (238)
            Tony,
