1967 Glovebox door alignment - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    To all,
    My 67 roadster's glovebox door just won't get centered on the dash. I've tried moving the frame, etc, but it is still off center. Is this a 67 issue as my 63's door lines up perfectly on center.
    Any ideas?
    Jerry
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 1967 Glovebox door alignment
    Jerry,
    Give us more info, door alignment, alignment near the dash pads....or on the lower cross brace?
    • Gerald C.
      • June 30, 1987
      • 1299
      Sorry, I should have been clearer in my explanation. The top of the door is not centered on the dashpad. It looks like the hinge is level and in line with the cross brace.
      I hope this helps
      Jerry
      • Michael G.
        • January 1, 1997
        • 1251
        Gerald,
        The glove box hinge has oblonged attachment holes for adjustment. Slightly loosen the three screws and slide door left or right to get alignment.
        • Gerald C.
          • June 30, 1987
          • 1299
          Mike
          I tried that and when I tighten the screws, it goes back into a "misalignment" status. I just wonder if I make larger holes in the support brace to give me more play.
          Jerry
