Re: C1 (1960) high performance oil pan
Tom, thank you for the helpful pictures. As a clarification regarding your pictures above, is this an original GM 1st design pan that was installed on 1960 assembly line cars, and is 100% correct for NCRS judging? It is my understanding the 1st design (non-service replacement) 1960 pans have one vertical long line on each side of the sump area? The Service Replacement pans have 3-lines on one side and 4-lines on the other. Is my understanding correct? Thank you in advance.
