Mid 70's Master Cylinder Casting Numbers - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    Anyone out there have a mid 70's documented car with a Power Brake Master Cylinder with the casting number 29969 on the side. I have seen a couple of cylinders with this number (including my 75) and I suspect these may be replacements but not sure. The correct Master Cylinder for my car should be 5460346. Is it possible that a second supplier may have build these for OEM usage? Any help would be appreciated. Thanks, AL
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
    Re: Mid 70's Master Cylinder Casting Numbers
    There are quite a few aftermarket suppliers of 'clone' master cylinders for these cars. They include Bendix, Cardone, Centric, Wagner and others...
      • 43259
      Alger------
      I can tell for ABSOLUTE CERTAIN that any master cylinder with the casting number "29969" was never originally installed on any Corvette. Such a master cylinder is an AFTERMARKET piece. It's very possible that it was supplied in a Delco box, but it's not a GM-manufactured piece or a piece that was originally installed on a Corvette.
