1964 -4-speed transmission part - NCRS Discussion Boards
  • Jack J.
    • July 31, 2000
    • 640
    Is the 3rd and 4th gear shifter shaft and detent plate part readily available today? My threaded end has a portion broken off but just enough thread for the nut. Thanks in advance
    • 43246
    Re: 1964 -4-speed transmission part
    Jack------
    The GM piece, GM #3831709, was discontinued without supercession in September, 1983. However, I think these are available in the aftermarket now. I'd check with Larry Fischer. If there's one available, he'll have it. If not, he'll be able to sell you a good used piece.
    • Wayne M.
      • March 1, 1980
      • 6414
      Jack -- there's always some on eBay. Here's a link to a '63-68 fine threaded stud type. Same shaft for 1-2 or 3-4 shift. If you troll a while, you might even come across a complete '707' sidecover with both shafts and the detent cams [scissors] and spring for a reasonable price.
      • Jack J.
        • July 31, 2000
        • 640
        Joe & Wayne, Thanks for the info.
        • Eric D.
          • February 1, 1992
          • 42
          You might try Crash Enterprises, he has a lot of Muncie parts... Eric
          crash_enterprises@yahoo.com
          • Jack J.
            • July 31, 2000
            • 640
            Thanks Eric.
