66 power steering shaft end play - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2163
    Can any one tell me if it is normal for the power steering pump shaft to move in and out (with the belt off) about .100? I had it apart and resealed it. This seems to me to be too much movement. Thanks in advance.RS
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 66 power steering shaft end play
    Russ,
    I think the pump shafts on my 67 and 63 move in/out like you are describing.
    • Jim S.
      • August 31, 2001
      • 730
      It is normal for the driveshaft to have some movement in and out. I just can't find any specification on the amount. 0.100 inch sounds about right. No movement side to side though.
      Jim
