C-1 fuel pump leak - NCRS Discussion Boards
C-1 fuel pump leak
  • Bruce M.
    • December 2, 2010
    • 14
    C-1 fuel pump leak
    The bottom of my furl pump has two screws and is shaped like
    a shalow bowl. It is leaking where a gasket is pressed out past
    the mating edges. Can I remove this lower piece without draining my gas tank? can a new gasket be made from sheet material? Any help is
    appreciated before I try this.
    thanks,
    Bruce Marler
  • John F.
    • March 23, 2008
    • 2417
    Re: C-1 fuel pump leak
    What you see sticking out is the outer edge of the diaphragm. You need to buy a rebuild kit.
    • Karl L.
      • February 1, 1977
      • 174
      Bruce,
      John is correct in saying you need to rebuld your fuel pump.
      Be sure that no fuel entered into your oil system.
      Some, (but not all) fuel pumps would leak fuel into the block when the diaphragm went bad.
      If the oil smells like gas, don't start your motor. Good way to wipe out the bearings.
      Good luck.
      Karl.
      • Dan D.
        • November 5, 2008
        • 1323
        I can second that. Back when, I had an Oldsmobile engine (in a 1952 Ford conv.), and I wiped out a rod bearing cause of gas in the oil. To be on the safe side, change the oil before you run it again. -Dan-
        • Domenic T.
          • January 29, 2010
          • 2452
          I blew a valve cover almost all the way off from a lean backfire that ignited the breather tube to air cleaner fumes on a Pontiac because of fuel pump dumping fuel in the oil.
          DOM
