C2 glove box removal - NCRS Discussion Boards
  • William F.
    • June 9, 2009
    • 1364
    Need to get to heater vacuum switch behind glove box on my '67 factory AC coupe. Couldn't find best way to remove glove box in archives. A lot of talk about difficulty in removing wire from glove box light though. Help for whole process appreciated.
    '67 L79 factory AC coupe &'67 roadster
  • Dan H.
    • July 31, 1977
    • 1372
    Re: C2 glove box removal
    William, the best way is to remove the small screws from the curved frame behind the glove box door, then the large philips screws in the cross member above the Vin plate. The whole thing will come out intact. You will have to cut the orange wire and resplice it later or put an quick disconnect in it. Removing it from the socket can be hard and damage may result to the socket. After you remove the small screws, lock the door to help prevent it from whacking you when you slide the assembly out. GOOD luck!
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Michael J.
      • January 27, 2009
      • 7166
      And don't forget to reattach the screw to the spring on the door.
      • Dan H.
        • July 31, 1977
        • 1372
        Michael, you can remove the whole assembly, door and all, just be carefull not to let the door fly open and whack you. Once the wire has a 'connector' the next removeal is a five minute job!
        • Harry S.
          • July 31, 2002
          • 5342
          AND, don't forget the orange wire is always HOT. Be careful or disconnect the battery!!!
          • William F.
            • June 9, 2009
            • 1364
            Where do I cut the wire to the light? Is there enough slack so that I can cut it behind the liner when I get the assembly part way out so a splice won't show?Thanks
            • Dan H.
              • July 31, 1977
              • 1372
              William, when loose, you can set the glove box in your lap/knees and see how much 'slack' there is. I cut mine about a foot back. I added some extra wire for convenience next time. It all hides up behind the box nicely.
              • William F.
                • June 9, 2009
                • 1364
                Thanks for all the help!
