part # id help. - NCRS Discussion Boards
part # id help.
  • Ken C.
    • August 31, 2006
    • 120
    part # id help.
    i have a seal i'm trying to id. GM plastic wrap with #14079472-seal
    GR.5.822-75D4
    I found some old Delco boxes with rear spindel bearings, spacers. figure they must go with them somehow?
  • Larry H.
    • May 31, 1994
    • 63
    Re: part # id help.
    Ken,
    #14079472 seal is the rear outer wheel bearing seal for 1963 to 1982. It replaced #3794006 in 1984.
    Larry
      • 43272
      Re: part # id help.
      Originally posted by Larry Hardesty (24649)
      Ken,
      Larry
      Larry and Ken------
      Yes, and I believe the difference between the two seals is that the 3794006 was a sort of "sandwich" type construction with a flat elastomer seal "sandwiched" between two steel outer plates. The 14079472 is a much more modern design using a lip seal somehow fused to the steel shell. The latter design results in considerably less "drag" on the spindle.
