71 heater control vacuum hoses - NCRS Discussion Boards
    • 15601
    Re: 71 heater control vacuum hoses
    A) If the wiper door vacuum relay is by the master cylinder (1970 and some 1971) the T will be as shown in my photo. In this case I believe BB & SB are the same.
    B) If the wiper door vacuum relay is in the fender well (1968, 1969, some 1971 and all 1972), I believe BB and SB will have this T at different locations as mentioned above.
    Vince, I assUme you don't have any of the original vacuum hoses to use as a clue as to where the T was located originally.
    Don’t you just love vacuum systems? They suck.
    • Vincent F.
      • August 31, 2006
      • 202
      needed that laugh, my early 71 has it in the fender. tour my garage apart and found the original hose with the T still in it. Its right where Kens pic shows it. problem solved, thanks to all.
      I have no hair left
        • 15601
        Back when we were doing research for the 1993 version of the 1970-72 TIM&JG I was visiting a friend who owned an LS6 Corvette (13K s/n range) it had/has the windshield wiper vacuum relay valve at the master cylinder (see Dobbins' Vette Vues Fact Book 1968-1972
        • Vincent F.
          • August 31, 2006
          • 202
          mine is s/n # 1356 71 LT1 convert. relay in the fender area.
          • Kenneth T.
            • March 23, 2008
            • 631
            As a follow up, my car is the last day of production #21715.
            The chrome valve covers are not correct
