1958 with electronic tach. - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 672
    I have a friend I am helping get his car finished and he forgot that the tach is mechanical. Any ideas on how to convert to electronic 8000 RPM?
    thanks for any help
    RDR
  • William C.
    • May 31, 1975
    • 6037
    Re: 1958 with electronic tach.
    As I recall, if the original tach is removed, a Sun (or similar) tach can be secured in the hole without cutting.
    Bill Clupper #618
    • Bruce B.
      • May 31, 1996
      • 2930
      Autometer makes a nice 8000 rpm tach but the face has a distinct look.
      The same with Sun tachs.
      If you don't mind the non-original look either one is a nice unit.
      But check fit before buying, I hate to see the early instrument clusters cut.
      • Tim S.
        • May 31, 1990
        • 715
        http://www.classicinstruments.com/in...=customcorvett
        • Mark P.
          • May 13, 2008
          • 951
          I got my electronic tach from this company for my 245HP 1960:
          They should be able to make a high RPM electronic tach that will look and fit like an original tach.
          They were easy to deal with.
          • J O.
            • August 31, 1987
            • 19
            ron.
            i bought my 58-8000 rpm -electronic tach from ' corvette clocks' by roger in tennesee..#731-664-6120----web.. corvetteclocks.com...........
            i saved and stored my original fi tach.... the replacement electronic tach was identical and perfect.....
            hope this helps.
            john.
