L-48 head gasket sealer for steel gasket - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    Should there be some sort of sealer for the GM steel head gaskets for this engine.
    It is currently being rebuilt completely.
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
    • 43258
    Re: L-48 head gasket sealer for steel gasket
    Steve-----
    Use aluminum paint or Copper Coat. Many replacement steel shim gaskets are pre-coated with aluminum paint. If so, you don't need to use anything.
    • Steve L.
      • June 30, 2001
      • 763
      Thanks again Joe
      Steve L
      73 coupe since new
      Ottawa, Canada
        • 15706
        What Joe said, but the Fel Pro .015" steel shim gasket has a polymer coating, and I don't think it needs any kind of added sealer. If you use this gasket, follow the Fel Pro installation instructions, which should be on the packaging.
        • Domenic T.
          • January 29, 2010
          • 2452
          I have used copper coat ever since it came out and totally agree with Joe & Duke. I just want to add that if the head & block surface is not perfect you may need it with that gasket.
          I usually spray 2 coates on each side of the shim gaskit and after you torque it you will see tiny droplets that squeezed out that wipe off with laquer thinner or another strong solvent.
          DOM
