'62 fuel sending unit - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    Anyone have the correct part number for the fuel sending unit on a '62?
    Thanks!
    ho,ho,ho!
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Re: '62 fuel sending unit
    David, P&A group 3.107, 2nd design with 3/8" pipe part # 1518785 Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • David H.
      • November 11, 2009
      • 777
      Thank you Gary.
      Was there also a # 5642125? What was that?
      • Michael M.
        • February 1, 1993
        • 606
        David, #5642125 is also in Group 3.107. It says 1956-62 (EXC. 24 GAL. Tank).
        • Gary C.
          Administrator
          • October 1, 1982
          • 17940
          David, 151878 was superceded by 5642125 on 6/1/62. The 1st P&A I checked was dated prior to that. Gary....
          NCRS Texas Chapter
          • Mike E.
            • February 28, 1975
            • 5141
            56-61 sending units had fitting to coupler to fitting for metal line down to frame, 62 had flared end for rubber coupler. In other words, 56-61 line to frame was all metal, 62 nad a rubber hose between. That could be the difference--Joe may know better.
            • David H.
              • November 11, 2009
              • 777
              OK, so my car being a Nov. '61 build date would have had the earlier 1518785 sending unit. But both would work, and it would have the rubber connector from the sending unit metal line to the metal line on the frame. Sound right?
              • David H.
                • November 11, 2009
                • 777
                What is part number GM Part number 6428065 that is listed on ebay?
                • Erich C.
                  • January 31, 2007
                  • 137
                  My parts book ( dated 12-83 ) lists # 6428065 as fitting 63-67 (exc 36 gal. tank )
                  • David H.
                    • November 11, 2009
                    • 777
                    Thanks Erich, That makes sense. His description heading says '62 but his description detail says '63. I dont think he knows what he has.
