53 to 57 speedometer repair - NCRS Discussion Boards
  • Robert J.
    • September 30, 2004
    • 117
    I have a speedometer that has sat for about 35 years......will not turn.
    I took it apart and everything is lose except the main shaft and gear (the one the cable fits into) it is frozen solid. I have soaked it in penitraiting oil for a day now, still frozen. Does anyone know how to break the shaft free? Is there a locking device behind one of the little plugs? Does it just press out? Is there a diagram out there ? Thanks Bob
  • Terry D.
    • May 31, 1987
    • 2698
    Re: 53 to 57 speedometer repair
    Robert
    I would suggest looking in the Driveline under services and contact a few of the people who repair these gauges. Most are pretty busy and may not have the time to read this board.
    • Robert J.
      • 117
      Thanks for the Info. I'd thought someone out there would have taken on apart?
      • John S.
        • July 29, 2009
        • 640
        any update? i have the same problem! i also need to locate a repair cable. i have the original 62.5" outer core and am looking to replace the inner cable. ( speedometer replacement cables are 67.5" )
        • Robert J.
          • 117
          John; Roy suggested that I drop the small case with the frozen shaft in boiling water for a few minutes. It broke free in no time. That was too easy. I fixed my cable with a new end piece. They crimp on. bob
          • John S.
            • July 29, 2009
            • 640
            thank you! same situation were car sat for close to 30 years. unfortunately cable is frayed too far for repair piece. i'll try to locate a inner replacement cable.
            • Cathy S.
              • August 31, 2003
              • 293
              Roy sure does know these cars
