automatic trans question... - NCRS Discussion Boards
  • Kevin N.
    • September 30, 2002
    • 88
    my question concerns the years 68-82. i am tring to figure out which years the 350 turbo was the designated trans and which years the 400 turbo was the designated trans. were there any years that you had a choice? did one come with the small blocks and one with the big blocks? thanks in advance...
    • January 31, 1988
    • 43196
    Re: automatic trans question...
    Kevin------
    For 1968-75 all Corvette automatic transmissions were THM-400. For 1976-77, things changed. For these two years the L-48 was equipped with THM-350 and the L-82 was equipped with THM-400. For these years, the engine ordered determined which automatic transmission was supplied (if an automatic transmission was ordered) and the transmission, itself, was not otherwise customer orderable.
    For 1978-81 all Corvettes equipped with automatic transmission used the THM-350, although several different variants of it were used over the model years. For 1981, a lock-up converter was standard.
    For 1982 ALL Corvettes were equipped with a THM-700R, the first use of a 4 speed automatic in a Corvette..
    • Kevin N.
      • 88
      thanks joe...i thought it was something like that. i will put this info in my folders for future use. thanks again...
