67 AC L79 battery cable - NCRS Discussion Boards
  • Craig O.
    • July 31, 1983
    • 207
    I have to replace the long positive cable, and mine has the square head threaded hex head bolt. it sure looks original to the car . were all cables spring ring or could they have used this type? it also has Packard writing on the wire cover .
  • Bob H.
    • July 31, 2000
    • 809
    Re: 67 AC L79 battery cable
    Craig:
    All were spring ring to my knowledge including my 67 air car.
    Bob
    • Peter L.
      • May 31, 1983
      • 1930
      Craig - As Bob said, the original battery cables had the spring ring ends. What you have is a Packard replacement cable or cables. Someone probably replaced the originals because they were a PITA and sooner or later in the good old days you replaced the cable ends or installed new cables. Pete
      • Larry M.
        • January 1, 1992
        • 2694
        Very true!
        Larry
