'TR' Head Markings on Bolts - NCRS Discussion Boards
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 'TR' Head Markings on Bolts
    Production line large TR's start in 69. I also have seen at least 4-5 different TR sizes. I also have several examples of the backwards TR which seams to be a solid axle era. Lastly I have many backwards L timing chain fover bolts!
    Rich
    • Rich P.
      • January 12, 2009
      • 1361
      Rich
      I need to clarify Large TR VALVE COVER BOLTS started in 69.
      Rich
      • Tom M.
        • 716
        #18
        Rich
        thanks Rich.
        • Mike B.
          • July 31, 1994
          • 843
          #19
          Doug and Rich,
          A couple of years ago I bought this guy out of as many '60s period bolts he had that were in good to excellent shape. Really enjoyed picking through and separating them back home. What a shocker to find 2 excellent black phosphate backwards TR bolts among them. They both measure: 5/16-18 x 3/4" grade 2.
          Same size as midyear headlight support rods etc...
          Doug, is yours the same size?
          Mike
          • Ronald L.
            • October 18, 2009
            • 3248
            #20
            Rich, thanks for jumping in here with what you have seen, it is nearly what I expected as there were more of these large TR's I found in the "fasteners box" for motors in this early C3 time frame. With the grease on them, I am sure they came off these motors.
            Mike the head light support brace part is 122007, you can see many a post on that part number. You have the spec down correct, but head mark on four 1966 original cars througout the year was RSC.
            • Doug F.
              • November 1, 1983
              • 322
              #21
              Originally posted by Mike Browning (24893)
              Doug and Rich,
              Mike
              Mike, same as you describe only mine is zinc
              • Ronald L.
                • October 18, 2009
                • 3248
                #22
                spec on the 122007 is zinc or cad but I expect for as poorly as they lasted the supplier was using zinc.
