1990 Body Control Module ,help !!! - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    1990 Body Control Module .......dealer Can't Get Me One , Does Anyone Know Who Can Fix Mine Or Where I Can Get One ????
  • Guest
    Re: 1990 Body Control Module ,help !!!
    Paul try one of these C4 salvage companies.
    JUST CORVETTES is in ST. CHARLES MO phone# 646-947-6060
    VETTE PROS is in CHARLOTTE NC phone# 704-249-0437
    GOOD LUCK
    MARK TULLEY
    • Alan D.
      • August 31, 2000
      • 111
      Here is a used one on e-bay. http://cgi.ebay.com/ebaymotors/1990-...item19be0a2815
        • 43277
        Paul------
        The module was GM #16146688 but it is GM-discontinued. You can get one from Auto ECM's (www.autoecms.com). This will be a reconditioned unit but the GM units were sold as reconditioned, too. These are not cheap but they wouldn't have been cheap if you could have gotten one from the dealer.
        • Ken A.
          • July 31, 1986
          • 929
          Contact us if you need a 90-96 BCM. As far as I know we are the only company who has access to the OEM Delphi parts and who can program your mileage. A used part will have different mileage than your original part.
          • Paul S.
            • June 30, 1982
            • 359
            Thank You To Everyone!!!! This Discussion Board Is Great !!!!!!!!!
            • Kenneth B.
              • August 31, 1984
              • 2091
              This ie why I like the C-1& C-2 Corvettes. If you have fuel,spark & compression it will go. As I have said before Gm has turend there back on people that bought 80"S & later Corvettes. Sometimes newer is not better. There are going to be a lot of later model cars up on blocks because no eelecteical/sensors & other cheap parts that were used . The newer ones did go fast with cold air blowing up your A** but at what cost for those that need parts. 15 years ago I could get GM parts for a 56 Corvette. A sad day in Mudville.
              KEN
              • Joe M.
                • February 1, 2005
                • 590
                Had that go on a 2001 impala.
                Battery kept going dead. discovered which circuit/fuse was involved, pulled the fuse whenever I shut off the car. worked well until we could get a BCM from GM parts direct and then had to have a dealer put it in as they apparently were the only one's who could.. they used the vin to determine how to burn it.
