69 Shoulder belt plastic screw issue - NCRS Discussion Boards
  • Steve M.
    • October 21, 2008
    • 59
    I am currently redoing the carpet in my 69 vert. I have located the factory mounting holes for the shoulder belts that my beautiful wife requested for safety. This was not originally a shoulder belt car but I now have the factory correct belts and guides.
    The problem:
    The plastic screws the factory installed to block this hole had obviously deteriorated and came off in my hand, leaving the threaded part still in the hole.
    I have tried everything to get the little piece of plastic out but no luck. I am hoping for any suggestions. I thought about trying to melt them out with a soldering iron and then perhaps running a tap in there.
    If I am able to get a tap in there, does anyone know what size and whether they are fine or coarse threads?
    Thanks in advance.... my wife really thanks you. ( I tried to explain unsuccessfully that she likely stood a better chance being thrown out of an old vette than getting held in with a shoulder belt....Ha)
  • Phil S.
    • November 2, 2010
    • 4
    Re: 69 Shoulder belt plastic screw issue
    I would heat up a sharp screw and then insert it in the middle of the hole while hot. Once it cools try to unscrew or pull it out. A drywall screw might work.
    • Steve M.
      • October 21, 2008
      • 59
      thanks, Phil worked like a charm....
      Do you have the specs on the proper size bolt to use to attach the shoulder belt assembly? length as well?
      They appear to be coarse threads.
      • Terry B.
        • August 31, 1999
        • 607
        Steve,
        Here is what you should use for the bolts:
        https://www.paragoncorvette.com/p-35...hor-bolts.aspx
        And don't forget this for storage of the shoulder belts:
        https://www.paragoncorvette.com/p-35...um-saddle.aspx
        Good luck,
        Terry Buchanan
        Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
        Corvettes Owned:
        1977 Coupe
        1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
        2003 Electron Blue Coupe
        2019 Torch Red Grand Sport Coupe
        • Steve M.
          • October 21, 2008
          • 59
          thanks..!
          Those parts indicate they are for up to '68.
          Mine is a 69. The 69 has shoulder belt guides up on the top edge of the seat so I don't believe they fully retract.
          • Terry B.
            • August 31, 1999
            • 607
            Sorry Steve, I misread your year. Dah!
            What you need should be on one of these three pages.
            https://www.paragoncorvette.com/c-23...-hardware.aspx
            Terry Buchanan
            Corvettes Owned:
            1977 Coupe
            • Reba W.
              • 937
              I do not judge C2s, but I don't believe those are on 1966-67 either--1968 only item.
