1963 Fuel Pump Inlet fitting - NCRS Discussion Boards
  • Alexander M.
    • January 1, 2006
    • 48
    Does anybody know the correct finish (brass or chrome) of the fuel pump inlet fitting for a May 1963 build w/FI? The guide says if the lines are chrome, then all the fittings are chrome, but I have not found a vendor that sells the pump inlet fitting in chrome?
  • John D.
    • December 1, 1979
    • 5507
    Re: 1963 Fuel Pump Inlet fitting
    Al, Vendors sell a chrome fuel line kit that has the chrome fittings with it.
    Inlet fitting. Do you mean the fitting that feeds the main fuel line going to the tank?
    If so then Long Island has it in their catalog. See Section #22.
    It's not chrome. The chrome fittings are for the fuel line going to the fuel filter down to the pump.
    Long ago Michael Hanson and others discussed the plating on this fitting.
    Some said it was brass and some said it was chrome. Maybe he will chirp in. JD
    • Alexander M.
      • January 1, 2006
      • 48
      Hi John,
      I am looking for the fitting that screws directly into the primary fuel pump on the inlet side.
      Al
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 886
        Al, All the original 340 and 360 hp cars I have seen have a brass 90 degree fitting and a short steel line.
        Joe
        • Stuart F.
          • August 31, 1996
          • 4676
          Mine is an original L-76 and I can concur. It is a 90 degree brass fitting, facing back toward the frame rail with a short steel line with flare fitting. Usually, the steel line is angled up to accept a rubber connection hose from the main fuel line which is also angled upward to form a upward bow in the hose. Disconnecting this line at any juncture will usually bring about drainage from the tank. Always have a plug handy, or at least that has been my experience. Believe the last time I changed pumps was in the mid 70's. All fittings were replaced as I found them with a new hose.
          Stu Fox
          • Alan D.
            • January 1, 2005
            • 2046
            Well not 63 and know changes were made in the fuel line area.
            It's my original from a Mar64 FI - it will give you an idea of what it should look like. As for finish, its not chrome but appears to be zinc.
            • John D.
              • December 1, 1979
              • 5507
              It would be nice if someone could post a pic of the 63 fitting all by itself. Thanks. JD
              • Wayne M.
                • March 1, 1980
                • 6414
                How about this ? Been almost 30 years since I sold my '63 FI and IIRC this was off that car. I notice the repop parts books call for this for all '63's. My '65 AIM seems to indicate this configuration for base and L75 engines; the solid lifter SB's take the fitting shown in Alan's pic. Per the '65 TIM&JG, the tower clamps were '63, maybe '64, but not '65 -- no description of the inlet fitting given.
                • William C.
                  • May 31, 1975
                  • 6037
                  That is because the '64-65 SHP engines used the 40083 pump with fittings 180 degrees across from each other, the '64 uses a different pump with the inlet and outlet at an angle from each other rather than straight across, The '63 configuration is closer to the '62 than the it is to the '64. Pump for '63 is either a 4656 or 4657 as I recall, don't have the JG handy right now...
                  Bill Clupper #618
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    John,
                    When I discussed the fittings and their plating, I was refering to the fittings at the fuel filter. Cars before 3 January had zincad plated fittings and cars after that had chrome. (along with other engine components)
                    The 90* fitting at the fuel pump was natural brass.
                    • John D.
                      • December 1, 1979
                      • 5507
                      Michael, Thanks for clearing up my feeble mind again.
                      So Al did you get that? The fuel pump has two fittings. The other fitting on the pump is chrome and the chrome fuel line screws into it.
                      Maybe Michael Hanson will dig into his vast collection of photos and pull one up of the natural brass fitting. Thanks, JD
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Maybe I confused you JD. Sorry. No chrome fittings were used on the fuel pump. Only natural unplated brass.
                        The only chrome fittings would be at the fuel filter on cars built after 3 January 63.
                        • Dan H.
                          • July 31, 1977
                          • 1369
                          Hi Alan, that fitting looks similar to the one on the front of the plenum for PVC hose? Got a spare?
                          1964 Red FI Coupe, DUNTOV '09
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Originally posted by Wayne Midkiff (3437)
                            How about this ? .
                            That looks correct for a 63, Wayne. Used for all engines. It would be correct for 64-65 with 250 and 300 HP too, with the exception of the clamps.
                            • Alan D.
                              • January 1, 2005
                              • 2046
                              Dan, it does sort of! No extra of either. Had forgot about the different fuel pump in 63 so mine did not help only served to confuse, sorry Alex.
