63 Starter pt. no.and Date Stamping - NCRS Discussion Boards
    • 6950
    I recieved my 63 340/4 spd vert. today and am accessing the correct part no., and there stampings. The starter does not seem to have a part no. facing the normal direction on the housing, do they stamp no.s on the starters somewhere else or is it possiable there was no stamp?
  • Michael G.
    • January 1, 1997
    • 1251
    Re: 63 Starter pt. no.and Date Stamping
    Ed,
    Starter would be stamped and should be plainly seen....ending with #'s (I believe) 242 if an original starter. No big deal, found found mine at a swap meet. Start you a list Ed....
    • Wayne M.
      • March 1, 1980
      • 6414
      I recieved my 63 340/4 spd vert. today and am accessing the correct part no., and there stampings. The starter does not seem to have a part no. facing the normal direction on the housing, do they stamp no.s on the starters somewhere else or is it possible there was no stamp?
      Edward --- IIRC, some V8 Pontiacs with a driver-side mounted starter have the Delco stampings on the case clocked differently. I know that there's Pontiac starters with numbers close to the 1117352, (correct for a '65 L78 396 engine), but with the last digit off either way -- I forget exactly. These numbers can't be seen when installed on a car with passenger-side starter.
      • Harry S.
        • July 31, 2002
        • 5330
        63's are 1107242 and are date stamped. The solenoid ends in 910.
        • Kenneth S.
          • July 31, 1981
          • 302
          Here's a picture of the one on my '63.
          Ken
            As others have mentioned, the practice of physically where a given starter motor case was stamped varied with starter PN and target vehicle. Once a given original starter has gone through the aftermarket remanufacturing cycle, all bets are off as to what/how a given case might be stamped.
            Since starters were a high wear item, it's not unusual for the factory original to a given car to have been replaced in the prior ownership chain. Ditto for the starter's solenoid...
