C2 Cluster Paint - NCRS Discussion Boards
C2 Cluster Paint
  • Joel T.
    • April 30, 2005
    • 765
    C2 Cluster Paint
    Quick question..... Does anyone know a source for the black paint used on C2 instrument clusters? I have some scratches which I would like to clean up....
    Joel
  • Peter J.
    • September 30, 1994
    • 586
    Re: C2 Cluster Paint
    Joel,
    I used the old Krylon #1613 or the now "Industrial Krylon 1613" (it will it say it on the can). I have touched up my dash a few times from where the keys scratched it, perfect match - undetectable. My car is a 66.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11334
      Joel, I used a Dupli-Color semi flat. Results were "ok". I see Zip has a item that is available. Not certain if it's "typical".
      ZipSemiFlat
      p.s. here's a old thread showing before & afters.....
      https://www.forums.ncrs.org/showthread.php?t=66140
      p.p.s if you decide to change the lenses while you're in there.......be certain they are "concave"(valleys) not "convex"(hills). Guess what I did twice! Kudos to Timothy Barbieri then for reminding me.
      • Michael F.
        • June 4, 2009
        • 291
        Theres only one paint that will give you a factory trim finish and is designed to be applied without primer and will stick to chrome finishes and resists chipping.
        SEM trim black 39143
        Don't waste time and money on others. Do a google search on (SEM trim black 39143) you will find what you need.
        The flash makes it look glossier than it is
        • Jim D.
          • 2885
          Originally posted by Peter Johnston (25176)
          Joel,
          I agree. I've used Krylon #1613 on several cars. It's a perfect match to the original paint, covers well and holds up great.
          • Peter J.
            • 586
            Mike,
            That is a bold statement! I've used Krylon 1613 on three mid-years including mine over ten years ago and have had no problem with durability or adhesion without a primer.
            • Michael F.
              • June 4, 2009
              • 291
              Mike,
              Well, I am a bold guy!
              Krylon is good stuff. They have the best spray can nozzle in the biz. My comment wasn't about how bad the Krylon is. Just how good the SEM is.
              IMHO The SEM Trim Black is better.
              • Joel T.
                • April 30, 2005
                • 765
                Thanks guys!
                I will check them both out.. I just have a few scratches from working on the car as well as some marks from the keys swinging....
                Joel
