I need to replace the schrader valves on the manifold of the AC compressor on my 66'. The problem I am having is the openings to get the valve out is smaller in diameter than the removal tools you get at an auto parts store. I even tried the old style valve stem cap that had a removal end on it. Is there a special smaller diameter tool made to remove these R-12 AC schrader valves? Anyone else ever had this problem? It still has the original brass acorn caps on it. Could these caps have been tightened to much and reduced the top of the opening? It doesn't look like thiough.
