'68 Headlamps - NCRS Discussion Boards
'68 Headlamps
  • Brian W.
    • September 30, 1990
    • 216
    '68 Headlamps
    A retaining cup (part that holds the bulb) - what is the finish on this part? Mine look like they were plated but all after-market appear to be black. Which is correct?
    Brian
    • 6941
    Re: '68 Headlamps
    Brian, I would gander to say you are correct they were plated black oxide maybe? Like everything in the reproductions anything goes I would bet that during judging the black paint would fly though, since the deduction would be less that one tenth of a point.
      • 15599
      Re: '68 Headlamps
      Brian
      It has been a while since I have seen those parts on my 1970, but I remember them as gloss black. That means little to you and your 1968, however.
        • 43219
        Re: '68 Headlamps
        Brian
        Brian------
        The GM nomenclature for the part is RING. There were 4 different rings, each specific to one of the 4 headlight positions.
        The rings were finished in one of 2 ways:
        1) semi-gloss black painted
        2) stamped from pre-punch galvanized material.
        GM was using these by the millions per year and I expect that even if any were manufactured internally by GM, outside suppliers also manufactured them. I expect that the specs for the rings provided alternate finishes and that's why some are painted and some galvanized.
        • Grant W.
          • December 1, 1987
          • 407
          Re: '68 Headlamps
          Brian
          HI Brian
          The bulb headlight cup for a 68 is a galvanized gold irate finish, My final assembly date is June 8th on my car.
          I have other original headlight assemblies from early 68 cars and they are also a galvanized and gold irate finish.
          Black for 69 and up.
          Thanks, Grant
          • Brian W.
            • 216
            Re: '68 Headlamps
            Thanks Grant that looks like it.
            Brian
