Joe Lucia - C2/C3 Steering Gear Part Numbers - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    Joe Lucia,
    Can you please provide the part numbers for the various Saginaw steering gear assemblies that were used throughout the C2/C3 model years?
    Jim
    • 43272
    Re: Joe Lucia - C2/C3 Steering Gear Part Numbers
    Originally posted by Jim Shea (36737)
    Joe Lucia,
    Jim
    Jim------
    There are lots of them. Herewith:
    63-67 PRODUCTION GM #5677641 SERVICE GM #5677642
    1968 PRODUCTION GM #5699038; SERVICE GM #5677642
    1969 PRODUCTION GM #7806900, GM #7807759 SERVICE GM #7808927
    1970-71 PRODUCTION & SERVICE GM #7807759
    1972 PRODUCTION GM #7807759, GM #7812913, GM #7814141 then back to GM #7812913 SERVICE GM #7814141
    1973-74 PRODUCTION & SERVICE GM #7812913
    1975 PRODUCTION GM #7812913, GM #7819668 SERVICE GM #7812913, GM #7819668
    1976-82 PRODUCTION & SERVICE GM #7819668
    • Patrick N.
      • March 10, 2008
      • 954
      joe, where would the 5677649 fall? Pre 63?
      • Jim S.
        • August 31, 2001
        • 730
        Thanks Joe,
        I am going to try and obtain some of the gear drawings while I still know a few people at Saginaw Steering Gear/Delphi Steering/Nexteer.
        Jim
          • 43272
          Patrick------
          I have no record of any steering gear assembly of GM #5677649. If I recall correctly, that's the casting number of the steering gear housing used for 1963-82 Corvette steering gears.
          • Scott S.
            • September 11, 2009
            • 1961
            Jim------
            Joe,
            Pages 9-A1 and 9-A2 (Contents - Steering, Steering Gear & Linkage) are missing from the 1967 AIM. However, on UPC N36-A1 (Telescopic Steering Shaft Equip. - Contents) the 1967 AIM says "The same parts are installed the same as regular production" and then calls out the 1967 Gear Asm. by part number 5694401. The same page in the 1965-66 AIMs call out the same 5694401 part number.
            Was there a different PRODUCTION part number for the steering box with telescopic steering column, or is 5694401 referring to something else?
              • 43272
              Originally posted by Scott Smith (50839)
              Joe,
              Scott------
              While sheets A1 and A2 are missing from the copies we have of the AIM, I have a copy of sheet A2. It shows the 1967 steering gear as GM #5677641.
              GM #5694401 is the PRODUCTION part number for the 1967 steering gear assembly used with N-36. The steering gear assembly includes the steering coupler. Since the coupler is different for the N-36 option versus non N-36, the steering gear assembly part numbers are also different.
              • Scott S.
                • 1961
                Thanks Joe, I understand
