1970 big block intake seals - NCRS Discussion Boards
  • Nancy S.
    • October 5, 2010
    • 8
    Looking for some information on the rounded tab on the intake seals. Thanks
    • 43281
    Re: 1970 big block intake seals
    Nancy-----
    Well, they say a picture is worth a thousand words, so here are 3 pictures that ought to be worth three thousand words.
    These photos are from an NOS GM #3955528 gasket set which is an original 1969 L-88/ZL-1 gasket set. However, the end seals are identical to those used with a GM #3955526 gasket set used for 1970 LS-5 (I have some of those gasket sets too, but this one was easier to get at). Since I see you're new, I'll repeat my often-stated standard advice that none of the parts I have are for sale.
    • Nancy S.
      • October 5, 2010
      • 8
      Thank you so much for the pics. Because of the shape of the gasket does the "GM" stick out beyond the intake?
        • 43281
        Nancy-----
        Yes, it does slightly---enough for someone to see it if they look very intently and carefully. This is one of those "trendy" features that draws a lot of judging attention. It ought to be worth about 0.01 raw points but I'm sure that, in current practice, it draws more than that.
        • Nancy S.
          • October 5, 2010
          • 8
          Does anyone know where to get the 70 LS5 GM intake seals, part # 3955526. Thanks
          • Ronald L.
            • October 18, 2009
            • 3248
            Joe,
            Is this seal the same as the 427 version that preceeded the 454 part?
              • 43281
              Originally posted by Ronald Lovelace (50931)
              Joe,
              Ronald-----
              The 3955526 was first used for 1969 427's with oval port. It was later used for 1970 454's with oval port.
              The 3955526 is NOT a "seal". It is an intake manifold gasket set which includes side gaskets (for 65-72 oval ports), end seals, and a distributor gasket. GM never sold the end seals for a big block as a separate part. They were only available as part of a complete intake gasket set. While the 65-72 side gaskets differed for different head and manifold configurations, the end seals were the same for all the sets.
