What is the typical pattern for 67 kick panel screws? If you use 4 Phillips screws with integral washers and two Phillips screws with beveled washers. I know that 3 integral washer screws go along the edge but does the 4th usually go at the top along the air vent with the two beveled head screws along the bottom through the carpet?
Interestingly enough the Aim appears to call for six screws all of the same type (E1) 4751359.
Thanks.
Kirk
Thanks.
Kirk
