pneumatic headlights - NCRS Discussion Boards
  • Justin S.
    • October 18, 2010
    • 11
    Ok,I am a fairly new owner and everyone says the headlghts always come up on old vettes when you step on the gas too much. Is it possible to fix this? they also take forever to go down at night when i turn the headlights off. can I tune something a little to make them react a little better? thanks.
  • Michael D.
    • June 30, 1996
    • 536
    Re: pneumatic headlights
    Vacuum. Not pneumatic, and yes, vacuum system repairs are common. My advice would be to purchase the assembly instruction manual (AIM) and GM chassis service manual for your year.
    • Tom H.
      • December 1, 1993
      • 3440
      You have a leak somewhere. Check valve may be bad. Here's a link to one. Could be many things, but these are commonly found to be defective.
      http://willcoxcorvette.com/advanced_search_result.php?cPath=1860&keywords=che ck%20valve
      Here's a good link to troubleshooting the vac system.
      http://willcoxcorvette.com/instructi...function_2.pdf
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • Michael W.
        • April 1, 1997
        • 4290
        Here's another troubleshooting guide:
        Don't make the mistake of replacing pieces at random, complete the troubleshooting first. There is more than likely multiple leaks.
        • Bob D.
          NCRS Shipping Data Report Manager
          • April 30, 1996
          • 788
          I would also purchase a vacuum system routing diagram. It will show all of the components in an easy to follow wiring type diagram.
            • 3416
            Hi Justin,
            To use the trouble shooting guides that have been mentioned it's a good idea to have a vacuum pump with a gauge. It's really needed to test the functions of the various components the guide will indicate.
            I found it to be well worth the few $ they cost. Something like a Mity-Vac will do the job.
            • Justin S.
              • October 18, 2010
              • 11
              Thaanks everyone, found a leak on the realy for the windshield wiper door, lights go up and down great now.
