63-67 convertible nut plates - NCRS Discussion Boards
  • Jeremy H.
    • January 1, 1999
    • 260
    Does anyone know where I can find a pair of the nut plates that the convetible top bows screw into? These are the plates that float in a cage in the birdcage behind the rear interior quarter panels.
    Jeremy Hedges
    #31711
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 63-67 convertible nut plates
    I don't know for sure but Long Island Corvette has a very large inventory of parts try them. They have an online catalog on their web site. What happened to the original plates. If they are stripped as one of mine was you could try to use a helicoil it worked for me.
    • Peter L.
      • October 23, 2007
      • 85
      Not sure if your still looking (since this post is from 2002) but I just went thru that with my 63. I had to have them made. I have drawings of what they look like, and can get a set made for you if you are still interested.
      • David L.
        • July 31, 1980
        • 3310
        Jeremy,
        I know I have a pair of the nut plates as well as the bolts somewhere in my garage. I got them from a 63-67 Corvette in a salvage yard in Leominster, MA, in the early 1980's. When I get a chance I will look for them but don't hold your breath because it may take some time to find them. If you can find some elsewhere then go for it.
        Dave
        • Tom D.
          • September 30, 1981
          • 2137
          I have also read someone's "join date" as actual date of the post...
          /td
          https://MichiganNCRS.org
          Michigan Chapter
          Tom Dingman
          • David L.
            • July 31, 1980
            • 3310
            Jeremy,
            While looking for other parts I finally found the pair of original 63-67 plates that the convertible top bows bolt into.
            Enclosed is a photo. The overall length measures 4 1/16". Each is stamped "AS". I painted them back in the 1980's with black spray paint. One of them is nice but the other one has some pitting from rust.
            I assume that you have found a pair by now.
            Dave
            • Scott S.
              • September 11, 2009
              • 1961
              Originally posted by David Liukkonen (3775)
              Jeremy,
              Dave,
              Are these called out anywhere in the AIM? I thought they had to be, since they would not have been installed on a coupe, but I didn't see them where I expected to find them.
              Scott
              • David L.
                • July 31, 1980
                • 3310
                Scott,
                I do not believe that the plates are listed in the AIM because they are part of the convertible body assembly. I remember that when I removed them from a wrecked mid-year convertible at a junk yard in Leominster, MA, it was not that easy. I have to break a sheet metal retainer to remove them.
                Dave
                  Originally posted by Scott Smith (50839)
                  Dave,
                  Scott
                  Scott -
                  They're shown in the convertible lock pillar subassembly - UPC 1 Bolt/Weld, sheet A3, view "B", item #11, P/N 3824879 Nut.
                  • David L.
                    • July 31, 1980
                    • 3310
                    John,
                    My 1966 AIM is missing sheets A3 and A4.
                    Sheet A2 is page F32
                    Sheet A5 is page F33
                    My 1967 AIM does have sheet A3 with the 3824879 nut as well as the retainer, GM # 3797300, which I had to break to remove each nut.
                    Dave
                    • Jim S.
                      • March 1, 1986
                      • 1408
                      "My 1966 AIM is missing sheets A3 and A4.
                      Sheet A5 is page F33 "
                      My 66 AIM is the same way !Could one of you guys piost a picture of A3 and A4 so I can down load it ?
                      Thanks ,
                      Jim
                      Jim
                      • Michael H.
                        • January 29, 2008
                        • 7477
                        Scott,
                        Dave
                        Interesting that even cars that were assembled as hardtop only still received a pair of the nut plates. My 66 was hard top only and the plates are present, held in place by one correct soft top mounting bolt per side.
                        • Scott S.
                          • 1961
                          Scott -
                          Thanks John, now I see it.
                          Scott
                          • Scott S.
                            • 1961
                            Michael,
                            I thought maybe this was a 1966-67 only part, but in post #3 above Peter says he fabricated a pair of these for his '63. My '67 AIM shows these nut plates where John stated, but my '66 AIM is missing those pages (A3 & A4). The other AIMs (1963-1965) do have the convertible lock pillar subassembly page, minus "View B", so the 3824879 nut plate is not called out in the 63-65 AIMs. At least not in that section.
                            1963 AIM: Section 1, Sheet A8
                            1964 AIM: 1Bolting & Welding, A3
                            1965 AIM: 1BoltWeld, A3
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              Michael,
                              Scott,
                              I see what you mean. I can't find the part in the 63 AIM either but I'm pretty sure it's there somewhere. The 3824879 part number numerical value definitely shows that it was a part originally introduced for the 63 model year.
