Re: Changing Heat Riser B'Fly Valve on 63 L-76
Stu,
Why are you changing the heat riser? If it's not leaking just wire it open and retain the original configuration.. I don't think the flow is any better with the F/I spacer as the valve will open fairly straight.
I realize you are trying to control heat to the manifold, I am not sure you are gaining anything for the effort..
Stu,
