AC outlet temp - NCRS Discussion Boards
AC outlet temp
  • William F.
    • June 9, 2009
    • 1364
    AC outlet temp
    Just installed new POA valve "update"-actually a compressor cycler, expansion valve, and dryer, and recharged with real R12 on my '67 factory L79. Before work I was only getting 60 degrees from outlet. Now I'm getting 46 degrees, maybe 44, depending on whose thermometer you use, on recirculate high fan mode.80 degrees low humidity outside air.Heater valve is working. Shop manual says should be 40 or 42 degrees, but should I be satisfied and worry about something else?
  • William C.
    • May 31, 1975
    • 6037
    Re: AC outlet temp
    Are you checking it in a parked position or while driving? Original condensor or replacement? Both of these will have an effect on the temp. I'd probably leave it alone if you are getting temp in the 40's at the outlet.
    Bill Clupper #618
    • William F.
      • June 9, 2009
      • 1364
      Re: AC outlet temp
      Come on guys, I need some help on this AC thing. I'd really appreciate those with mid year, especially '67 AC cars letting me know what kind of AC outlet temps they get on max setting and with what kind of outside air temps. Please see my initial post about my particular system.You can also e-mail additional info if you like.
      • Kenneth S.
        • July 31, 1981
        • 302
        Re: AC outlet temp
        at 80 grill air temp. and 42 at 90.
        • Kirk M.
          • June 30, 2006
          • 1036
          • Larry M.
            • January 1, 1992
            • 2701
            Re: AC outlet temp
            AC duct temperatures as a function of outside air temp are listed on page 1A-33 of the 1967 Chevrolet Chassis Service Manual.
            They range from a low of 38-40 F for an outside air temp of 70 F, to a high of 45-47 F for an outside air temp of 120 F.
            AC duct temperatures are also shown for all outside air temperatures in between these two limits. This should provide the information you seek.
            Larry
            • Brian M.
              • February 1, 1997
              • 1841
              Re: AC outlet temp
              I'm getting 39 degrees from the center duct with an original unrestored system with outside temps in the 80's. 67 327/300
              • William F.
                • June 9, 2009
                • 1364
                Re: AC outlet temp
                Thanks for the replies so far-anybody else checked theirs?. Larry, I know what the book says you should get but what I want to know is what temps people are actually getting as compared to my 46 degrees and any suggestions to how to bring it down.
                • Donald O.
                  • May 31, 1990
                  • 1593
                  Re: AC outlet temp
                  Show off!
                  • Brian M.
                    • February 1, 1997
                    • 1841
                    Re: AC outlet temp
                    You gotta see the stiff nipples.
                    Originally posted by Donald Olson (17357)
                    Show off!
                    • Ray G.
                      • May 31, 1986
                      • 1189
                      Re: AC outlet temp
                      Hello William;
                      For what it is worth, while attending A/C class at the General Motors Training center in Milwaukee, as a young mechanic in the early '60s, we were taught the ambient interior temp. (not outlet) should be NO MORE than 25-30 degrees below outside temperature. The concern was people would pass out from the rapid temp. change when exiting their vehicle(s).
                      Also air flow through the condenser and radiator are crucial in determining the final outlet temp.
                      Regards.
                      Ray
                      I hope you dance
                      • Ken A.
                        • July 31, 1986
                        • 929
                        Re: AC outlet temp
                        Here's how it was done at a Chevy dealer in 1963 where I worked in the A/C dept in the summer in Ft.Worth, TX:
                        With system warmed up, set fast idle at 2000 rpm.
                        Place 3' shop fan in front of radiator.
                        Place A/C thermometer in PASS outlet.
                        After 10 min tops air should be at 38 degrees, if not adjust as needed.
                        Also we installed extra insulation wrap as needed and always made sure the drain tube was intact.
                        Never had a complaint or comeback. Remember, this is a refrigeration system, not an air conditioner!
                        • William F.
                          • June 9, 2009
                          • 1364
                          Re: AC outlet temp
                          Where did you put the extra insulation wrap?
                          • Dale S.
                            • November 12, 2007
                            • 1224
                            Re: AC outlet temp
                            William, my 67 coupe A/C is all original (no replacement parts). I have added a can of R-12, 3 or 4 times since 1970 when I bought it. (the system has never been opened since then). My temp. at the center outlet is 44 to 46 degrees when driving. ( I keep a A/C termometer in the vent all the time) . Dale
                            • Ken A.
                              • July 31, 1986
                              • 929
                              Re: AC outlet temp
                              On the cold pipe going into the evaporator & back from the expansion valve. Check the rubber drip valve on the box, as it rots and you lose a lot of cold air.
