Article showing 67 vent window rebuild? - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1336
    I need to rebuild my vent window regulators, but before I order the parts, I want to see what I'm in for.
    I have searched the archives, and I see some guys saying it is pretty easy.
    Does anyone have an article they can post that shows a step by step?
    Chris Enstrom
    2011 Z06, red/red
  • Keith G.
    • October 31, 2006
    • 316
    Re: Article showing 67 vent window rebuild?
    I've done two, they are pretty simple, parts come with instructions.
    • Steven S.
      • April 16, 2008
      • 26
      Yes, the rebuilding of the regulator itself is very easy. Messing with the door panel and vent window frame, not so much.
      • Chris E.
        • November 3, 2006
        • 1336
        How do they come out of the door? I have the panel off, and I pulled those few screws out, but I couldn't wiggle them out easily. Do I have to raise the vent window assembly up a bit to get them out?
        Chris Enstrom
        2011 Z06, red/red
        • Keith G.
          • October 31, 2006
          • 316
          Yes take the hole vent window assembly out, it is a little tricky, you have to hold your tonge just right.
          • Steven S.
            • April 16, 2008
            • 26
            On my 65 Roadster, I could not get the whole vent assembly out of the door withour removing the lower stud, so I chose not to do that. I did raise the assembly up a little to get the regulator off and on. It would help to have an assistant hold the assembly while you work on it so that you don't damage anything. The only things that hold it in there are the three screws and the bolt that attaches the t-post to the regulator shaft.
            • Scott S.
              • September 11, 2009
              • 1961
              Hi Chris,
              Do you have the Corvette Restorer Summer 2000 article titled "Overview of some Corvette (midyear) door anatomy" by David Zuberer? It's about 15 pages long with color photographs, and it was made available as a PDF document at some point. It's available for download on the Barry Kimmelman website: http://www.lbfun.com/Corvette/Tech/vettetech.html
              Not sure if this will work, but here is a direct link to the article:
              http://www.lbfun.com/warehouse/tech_...natomy-Mod.pdf
              • Chris E.
                • November 3, 2006
                • 1336
                Scott, that's PERFECT, thanks for the links.
                My new regulators from Paragon arrived today, so I'm going to try this over the weekend hopefully.
                Chris Enstrom
                2011 Z06, red/red
                • Timothy B.
                  • April 30, 1983
                  • 5203
                  Chris,
                  Let me know what you think about the Paragon repro regulators, my 67 convertible has one that's now broke. I am also interested if you have to remove the complete vent window assembly to replace the regulator..
                  • Chris E.
                    • November 3, 2006
                    • 1336
                    Chris,
                    Will do. I'm going to work on the car this AM.
                    Chris Enstrom
                    2011 Z06, red/red
                    • Chris E.
                      • November 3, 2006
                      • 1336
                      Tim, I installed the driver's side vent window regulator. It went in really easy. The trickiest part was getting the vent window mechanism out of the door WITHOUT removing the main side glass. It can be done, but it is tricky. I found that the screw at the bottom of the vent window support rod, if you unscrew that, it is a LOT easier to get the whole thing back in the door. Then, before you slide the whole thing all the way down into the door, put that screw back in.
                      Worked great.
                      My issue now is that I can't seem to get my door panel realigned. Grr.......
                      As for the Paragon vent window regulator, it is a REALLY nice piece. However, I found that the regulator wasn't really the issue. The regulator takes the motion of the crank, and turns it 90 degrees so it spins the vent window bracket, thereby opening or closing the window. There is a shaft that comes down off of the vent window bracket. That shaft was worn to the point where even WITH the new regulator, I still had 1/2 of a turn of free play in the knob. That is too much, according to the PV manual. I wound up sandwiching a stainless steel washer in between the shaft that comes down off of the vent window frame and the regulator. Now, I have 1/4 turn of free play, as the manual says.
                      I'm thinking that all I had to do was to take the original one apart, put the washer in, and put it back together. Could have saved $300......oh well. Now I have a good part in there that will be good for a LONG time.
                      Chris Enstrom
                      2011 Z06, red/red
