Choke pulloff - NCRS Discussion Boards
Choke pulloff
  • D S.
    • March 1, 2005
    • 1551
    Choke pulloff
    What effect does a cracked or chipped choke pulloff have on the carburetor?
    Scott Sims
    Texas Chapter
    • 43203
    Re: Choke pulloff
    Scott Sims
    Texas Chapter
    Scott------
    It depends whether the crack or chip renders the unit non-functional. If it doesn't render the unit non-functional, the crack or chip only represents an "aesthetic" problem. If it does render the unit non-functional, then the choke pull-off will not release the choke properly.
    The choke pull-off can be easily checked for basic functionality simply by applying a vacuum to the vacuum port. If the pull-off lever moves, then the chances are the unit is ok; if not, it's not working properly.
    If the problem is only a crack or a chip, you may be able to repair it with epoxy. Then, retest.
      • 15648
      Re: Choke pulloff
      It could also cause a vacuum leak. Check that it holds vacuum.
      • D S.
        • March 1, 2005
        • 1551
        Re: Choke pulloff
        Thanks. When cleaning the engine I noticed that the pulloff had been chipped on the edge and appeared to expose a small part of the diaphragm. It seems to hold vacuum. I have a replacement. By the way....on a '66 what does an original pulloff look like? Color? Markings?
          • 43203
          Re: Choke pulloff
          Scott------
          My recollection is that it was a tan colored plastic, but I'm not 100% sure. I think you'll find that replacements may be yellow or black.
            • 43203
            Re: Choke pulloff
            Scott-----
            By the way, I'll be interested to see what you get as a replacement for this piece. While I THINK the original for your application was a plastic-bodied piece as described, most Holley carbs used a metal-bodied vacuum choke unloader. I think that most of the replacements are metal-bodied.
            • D S.
              • March 1, 2005
              • 1551
              Re: Choke pulloff
              Joe, I bought two a few years ago for my 0204 Q-Jet. They are an off-white plastic and I see that they are still available in that color, I guess as reproductions. They call 'em NOS on eBay. New Overseas Stock? I'd prefer a new original in the correct color.
                • 43203
                Re: Choke pulloff
                Scott-----
                The Q-Jet choke pull-offs were mainly plastic bodied. Some of the later ones may have been metal, but all those through at least 1972 were plastic.
