66 V74 Question - NCRS Discussion Boards
66 V74 Question
  • Peter J.
    • September 30, 1994
    • 586
    66 V74 Question
    While finishing the interior I am at the wiring for V74 harness and the AIM calls for "twelve inches" of tape" to secure the harness to the steering column. My question, is this regular electrical tape or non-adhesive wiring harness tape adhesive?
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 66 V74 Question
    Peter, it was used all over the car, if you have original stuff, here are the other areas:
    Traffic Hazard-Warning Switch
    Less Heater EquipmentTransistor Ignition System
    Automatic Transmission - Brake Pedal & Neutral Safety Switch Wiring
    Radio AM/FM - CapacitorsEngine Wiring
    HarnessInstrument Panel Wiring Harness
    Rear Wiring Harness, Dome & Courtesy Lamp
    Air Conditioning - Engine Wiring Harness, Resistor & RelayAir Conditioning - Control Switch Wiring
    • Peter J.
      • 586
      Re: 66 V74 Question
      Thanks Ronald - I used narrow electrical because I thought they would have used wiring harness tape. I can cover it with harness tape now and it should be completely invisible. The old bones don't like climbing under that dash any more than they have to especially with the steering wheel back in.
      • Ray G.
        • May 31, 1986
        • 1189
        Re: 66 V74 Question
        Hello Peter;
        Wire harness wrap, not being adhesive and wider than electrical tape, has a different final result because it can equalize as it is wrapped around the wire(s).
        Just my 2 cents.
        Ray
        I hope you dance
        • Peter J.
          • 586
          Re: 66 V74 Question
          Thanks Ray - Point taken, if I'm going to do it in harness tape anyway I can loose the electrical tape.
          • Ray G.
            • May 31, 1986
            • 1189
            Re: 66 V74 Question
            Hello Peter;
            Don't know if the original harnesses were assembled by this method. Lay the wires out on a flat surface and fastening the wires together, with a single wrap, every 12-15" will keep the harness individual wires in line with each other. This also helps eliminates the uneven look after wrapping. We use clothes pins or larger pinch clamps as the loom is wrapped to keep the wires in line and pretape the joints.
            Hope this helps.
            Ray
            I hope you dance
