Deduct for non-tinted repop 67 windshields? - NCRS Discussion Boards
  • Chris E.
    • November 2, 2006
    • 1322
    Has anyone had a non-tinted 67 windshield run through judging lately? My car with a repop tinted windshield took a 10 point originality deduct, and the gasket took a 1 point deduct for excessive weatherstripping goop.
    I'm seriously contemplating replacing the essentially brand new windshield to recover those 10 points. The reason? I'm trying for Duntov, and my paint (at best) will get a 22 point deduct. I need as many points as I can. And the windshield is my biggest area of opportunity. Everything else (outside of battery at 8 points) is either 2 or 1 each.
    So, if I get a repop NON-tinted windshield, will it get a zero point deduct?
    Thoughts?
    Chris Enstrom
    2011 Z06, red/red
  • Brian K.
    • May 31, 2004
    • 358
    Re: Deduct for non-tinted repop 67 windshields?
    Chris, just thought I would give you a bump up on the list. I think you have an interesting question. Sincerely Brian
    • Chris E.
      • November 2, 2006
      • 1322
      Thanks Brian. I'm a little surprised no one has responded.
      Has anyone had a NON-tinted windshield through either Regional or National judging lately?
      Chris Enstrom
      2011 Z06, red/red
      • Scott S.
        • September 11, 2009
        • 1961
        Hi Chris,
        If you check this link, it has a detailed write-up by one of the CF members on the installation of a TINTED Pilkington replacement windshield to replace an original non-tinted windshield. He shows photos of the differences between the original glass and the replacement glass. I remembered this link because of another Thread this evening, and thought it might be helpful for you too:
        The original glass is thicker (.291" vs. .253"), and as mentioned, the original being replaced was clear, but I think the main difference I notice between a replacement tinted windshield and an original tinted windshield is the coloration. It's hard to tell from the picture, but the color of the tint on the replacement glass almost seems to have a bluish-hue to it, while the original tinted glass has more of a greenish-tint. Also, I think the distinction between the more darkly shaded area along the top and the rest of the windshield is more gradual and less abrupt on the original tinted windshields. It has been a while since I looked closely at mine though, and that was indoors in bad lighting. If my memory is incorrect, someone please set the record straight.
        • Chris E.
          • November 2, 2006
          • 1322
          Scott, thanks but I'm wondering about the deduct (if any) for a NON-tinted windshield.
          Chris Enstrom
          2011 Z06, red/red
          • Steve B.
            • February 28, 2002
            • 1190
            I would also like to know the answer to this.
            • Gene M.
              • March 31, 1985
              • 4232
              I think the non tinted windshield is standard equiptment. As standard equiptment the side window glass is clear too.
              I think the tinted windshield is a seperate option. Also available with all tinted glass. But I don't think you can have side windows tinted and not have a tinted windshield.
              So clear glass windshield and tinted side glass is not an option.
                • November 30, 1997
                If the logo and date is correct, why would there be any deduction? There's no tint band to worry about.
                • Jeff B.
                  • November 5, 2008
                  • 154
                  I agree with John, the basis of the deduction of my tinted windshield was the pattern of the tint band. I had done lot of research and found what I thought was a really good recreation of the tinting, but the judges at the regional did not like it and I took a similar deduct. Still got a 97.5 though. I would guess that a clear windshield would be very hard to fault if the stamping was correct, they dont' measure the thickness. I'm also working towards the Duntov on my 1964, but on the other hand I like the tinted windshield. Don't loose sight of the fact that you have to like YOUR car. You can loose 135 points and still have the Duntov level score. Changing a windshied is a risky operation and carries the possibility of trim and paint damage if a mistake is made. How about getting the points somewhere else?
                  • Steve B.
                    • February 28, 2002
                    • 1190
                    That's what I thought but I did not want to make any assumptions.
                    • Chris E.
                      • November 2, 2006
                      • 1322
                      Jeff, understood. The issue is that I missed my 97% by 22 points at the Des Moines Regional. Since then, I have spent some time working on the car and have recovered 20 of those 22.
                      Beyond that, to pick up more points, outside of the battery at 8 points and my paint (BC/CC) at 22, ALL of my deductions that I can pick back up are either 1 or 2 points at a time. The windshield is 11. (10 for the deduct for the tint band and 1 for excessive windshield sealant "goop" on my car)
                      I want to go to my next Regional with THE BEST shot at getting a 97 as possible. Plus, the one thing that putting the car on a trailer and taking to a show has taught me is that STUFF BREAKS IN TRANSIT. The first time to Iowa (Chapter) I lost a fuse and a turn signal switch. The second time to Iowa (Regional) I lost the horn functionality, and the squirters.
                      All that said, meaning that I can't just simply recover the 22 points I missed in Iowa and hope to get a 97%. I need a cushion. The windshield can provide that.
                      Plus, on the "you have to live with your car" comment, I would be fine with a non-tinted windshield in this car. Most of the time I'm driving the car, the sun is up over the top of the glass (and my sunglasses) anyway. No big deal.
                      So, overall, it sounds like NO DEDUCT FOR A NON-TINTED WINDSHIELD, eh? That's what I expected to hear.
                      Chris Enstrom
                      2011 Z06, red/red
                      • Tony S.
                        NCRS Vice President, Director Region VII & 10
                        • April 30, 1981
                        • 974
                        Hey Chris. Good question.
                        Was your car equipped with option A01 (tinted glass--all windows)? If it is, then you'd be subject to a 20 percent originality deduction for your windshield (remember: cdcif). If your side windows are tinted, your windshield would have to be tinted too. Under this example, an untinted windshield would not be configured correctly.
                        If none of your glass is tinted, then you could claim that your car had neither the A01 or the A02 option, which means no originality deduct ( assuming that the judges liked your logo and date stamp of course).
                        Good luck!
                        Tony
                        Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
                        Original member of the Kansas City Chapter, est'd 07/11/1982.
                        Member: 1965 and 1966 National Judging Teams
                        Judging Chairman--Kansas City Chapter.
                        Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
                        • Chris E.
                          • November 2, 2006
                          • 1322
                          My car originally had (according to the tank sticker) a tinted windshield ONLY. Good question Tony. 3 of the 4 side panels of glass are ORIGINAL to the car. Only the one with the NCRS sticker on it is not original to the car.
                          I'm thinking I can swap the tinted windshield for a non-tinted windshield and get my 11 points back.
                          Chris Enstrom
                          2011 Z06, red/red
                          • Terry B.
                            • August 31, 1999
                            • 607
                            I am also considering doing the same with replacing my windshield to pick up some points however there are still things to consider with the replacement windshields. Will the logo and date code stamping pass judging? I would like a sample to run past a master level exterior judge before I buy it. Will the installation be "like the factory?" I would try to get a picture or 2 of a bowtie car of your year to show the installers.
                            I don't like surprises on things I have spent big money to correct. Just my 2 cents. Good luck and keep us posted.
                            Terry Buchanan
                            Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                            Corvettes Owned:
                            1977 Coupe
                            1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                            2003 Electron Blue Coupe
                            2019 Torch Red Grand Sport Coupe
                            • Tony S.
                              • April 30, 1981
                              • 974
                              Chris. Sounds like you can put on a non-tinted window that is properly logo'd (is that a verb?) and you'll be in like Flint.
                              I'm planning on seeing you at Novi.
                              Tony
