I have been doing some work on my '66 L79 coupe, and have found 2 nylon washers, about 1/2 inch diameter, under the car on the ground. One was found under the left front quarter and one under the right front quarter. Any idea where nylon washers are used? Thanks for any ideas.
Nylon Washers?
Tags: None
- Top
Re: Nylon Washers?
Hello;I have been doing some work on my '66 L79 coupe, and have found 2 nylon washers, about 1/2 inch diameter, under the car on the ground. One was found under the left front quarter and one under the right front quarter. Any idea where nylon washers are used? Thanks for any ideas.
What work has been done?
Color, thickness, of the washers?
Under the front of the rear fenders(quarter panels)?
Under the front fenders?
I hope you dance
- Top
Re: Nylon Washers?
I have been replacing spark plugs, battery, cables, voiltage regulator, alternator, wheels and tires, and light and antenna switch under the dash. The washers are white nylon, about 1/4 inch thick, with a black spray around the edges, and found under the front fenders just behind the front tires. Thanks.Big Tanks In the High Mountains of New Mexico- Top
Re: Nylon Washers?
Hello;I have been replacing spark plugs, battery, cables, voiltage regulator, alternator, wheels and tires, and light and antenna switch under the dash. The washers are white nylon, about 1/4 inch thick, with a black spray around the edges, and found under the front fenders just behind the front tires. Thanks.
Sound like seat handle lock release handle washers from a '67.
Were they possibly used to mount the previous Voltage Regulator?
Try showing them to;
Peter Lindahl member #6598
Believe he is in your NCRS chapter.
Ray
I hope you dance
- Top
Re: Nylon Washers?
Thanks, will do when I see him at the regionals. It could be they are from the old VR mounting. I replaced those with the proper rubber bumper nuts and bolts.Big Tanks In the High Mountains of New Mexico- Top
