70 wiper door moulding screw - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Does anyone have or know where I can procure the two small screws that hold the wiper door moulding on the wiper door at both ends?
    I bagged and labeled them and now I cannot find them
    There are no slots. They are just rounded with grooves. They are just a pressure fit.
    Bill
  • Dick W.
    • 10483
    Re: 70 wiper door moulding screw
    The are called easy drive nails? available from McMaster Carr .http://www.mcmaster.com/#nails/=8nwj88 but don't ask me what size....
    Dick Whittington
    • Graeme B.
      • October 23, 2007
      • 213
      Hi Bill, they are called drive pins.A good industrial hardware should have them (fastener supplier). They come in many different size,the pins that is.
      Cheers, Graeme.
      • Bill L.
        • February 1, 2004
        • 1403
        You guys are amazing. Found the correct type. Now I just have to determine the correct size. I brought home the smallest they have and it is a little too big.
        Maybe 00. I am pretty sure I got the 0 locally.
        Bill
          • 15616
          Bill,
          I know McMaster Carr has them, but you will have to know the correct size and then you will have to buy enough for all of us. You might get close on the diameter using a drill bit, or better yet a set of carburetor pin gauges (everyone has a set of those, right? ) in the existing hole. McMaster Carr has a most excellent on-line catalog to give you some idea of what is available. You just might be able to get them in stainless steel to even satisfy Joe (Mr. Stainless) Lucia.
          McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
          Also do not overlook Fastenal, although I have no personal experience with them:
          http://www.fastenal.com/web/home.ex
