Vapor Barriers - NCRS Discussion Boards
Vapor Barriers
  • Richard R.
    • August 31, 1988
    • 98
    Vapor Barriers
    Is anybody repoping the vapor barrier's for C-3's
  • George D.
    • August 31, 2000
    • 225
    Re: Vapor Barriers
    Check out Mid-America web site part number 618-830.
    • Scott S.
      • September 11, 2009
      • 1961
      Re: Vapor Barriers
      Also:
      Paragon Number: 14478K
      Corvette Central part number: 133231
      • Kenneth T.
        • March 23, 2008
        • 631
        Re: Vapor Barriers
        Richard,
        The original ones were a almost clear heavy gauge plastic held in place with dum dum.
        The Mid America one looks good, I too am interested.
        The paragon and CC black thermal ones will not pass judging.
        Ken
        • Bill C.
          • July 15, 2007
          • 904
          Re: Vapor Barriers
          I just cut one from clear Vizqueen to match the door panel/door.
          It looks like factory and passed judging 3 times.
          ls ALOT cheaper too~
          • Kenneth T.
            • March 23, 2008
            • 631
            Re: Vapor Barriers
            Bill,
            I googled it and thought I would get Lady Ga Ga, but I actually found it.
            What mil do you use? thanks
            Ken
            • Bill C.
              • July 15, 2007
              • 904
              Re: Vapor Barriers
              Ken,
              I will have to take a look for you --- not really sure the MIL...
              • Bill C.
                • July 15, 2007
                • 904
                Re: Vapor Barriers
                it is 6 MIL
                  • 3416
                  Re: Vapor Barriers
                  Hi Richard,
                  The original vapor barriers were vacuum formed and quite intricately cut. The shape detail is great enough that there are left and rights. You just can't reverse a left, for example, to use as a right.
                  I believe all the reproductions are just flat material. Since you can just really see the edge of them, they may or may not 'measure-up' to judging.
                  I'm not aware of anyone making an accurate reproduction.
                  The dum-dum was in a thin bead that ran around the entire perimeter of the door and had a string embedded in it.
                  I continue to look for a passengers side shield, but VERY rarely see them offered.
                  Here's a couple of pictures of a driver's side shield from my 71.
                    • 15610
                    Re: Vapor Barriers
                    Please note the milk colored tint to the material in the above photos. That is NOT clear -- unless your eyesight is a lot worse than mine. If I were judging interior, and I almost always do not, I would make a deduction for clear vapor barrier.
                    And if you can hide it behind the door panels, especially the poor fitting reproductions, more power to you.
                    • Richard R.
                      • August 31, 1988
                      • 98
                      Re: Vapor Barriers
                      Thanks everyone for the info. This will be helpful. Thanks again Reed
                        • 43246
                        Re: Vapor Barriers
                        Terry-----
                        All of the commercially available "Visqueen" that I have seen has the "milky white" appearance. I have never seen any that I would call "clear".
                          • 15610
                          Re: Vapor Barriers
                          Terry-----
                          It must be a different material out west. Maybe they use corn in ours here in the Midwest.
                          • Bill C.
                            • July 15, 2007
                            • 904
                            Re: Vapor Barriers
                            Found this on the Corvette forum for anyone interested ..
                            NOS vapor barrier.
                            http://forums.corvetteforum.com/c3-p...3912972-a.html
